460 carb is frosting up
Posted by Dan (wi) on November 27, 2006 at 18:27:14 from (64.136.49.225):
The carb on my 460 is frosting up,believe its problem with coil on intake/counter weight on exhaust manifold,whats the chance of replacing these parts if I can split the manifolds.thanx dan
