Re: 460 carb is frosting up
Posted by ChadS on November 28, 2006 at 09:18:17 from (66.228.96.183):
In Reply to: 460 carb is frosting up posted by Dan (wi) on November 27, 2006 at 18:27:14:
Put in a larger venturi inthe carburator, that drops the manifold pressure (vacuum) slows the air down and does not get as cold as a smaller carb would. ChadS
