Re: Farmall 140-Fuel delivery problems
Posted by BobG in VA on November 28, 2006 at 14:26:22 from (152.163.100.65):
In Reply to: Farmall 140-Fuel delivery problems posted by Jack DeLong on November 27, 2006 at 12:46:27:
Had the same problem with a SC. Take the fuel line loose at the carb connetion. There should be a brass strainer inside the connection to catch anything that gets thru the bowl strainer. My SC was crammed full. Clean it out...You might as well take off the carb and give it a good once over as you may have some float issues as well. Once you take the carb apart (I assume a Zenith) and clean it out, blow it out with a good compressor nozzel. Worked for me. BobG in VA
