Re: Farmall H Loader, Hydraulics Problem
Posted by T.B.W. on November 28, 2006 at 17:37:05 from (4.248.240.175):
In Reply to: Farmall H Loader, Hydraulics Problem posted by Matt Compton on November 28, 2006 at 14:52:33:
I ran a line from the outlet on the belly pump to the" in "side of the spool valve. I ran a line from the return of the spool valve to the drain plug hole of the belly pump. When I wanted to use the loader, I locked the belly pump control rod pull out all the way and ran the loader up and down with the spool valve. I also conected the lines to the cylenders of the loader to the pressure side of the spool valve. worked great for me. the only problem is the clutch has to be out for it to work.
