Re: 140 farmall wiring
Posted by Hugh MacKay on April 12, 2009 at 03:37:15 from (216.208.58.140):
In Reply to: 140 farmall wiring posted by 69fastback393 on April 11, 2009 at 19:19:30:
Fastback: You've answered your own question, run those two wires back to the dash, and connect in a push button switch. Everytime you start the tractor hit the push button and it will excite the alternator every time. You'll find you can't leave those two wires connected as it will drain the battery when tractor is not running.
Toss the light and diodes in the dumpster. I've had 2 offset tractors on alternator charging for 18 years now. The tractor that has been push button excite from beginning, has been trouble free all those 18 years. The second tractor I played around with lights, diodes, etc., was continuous trouble until 4 years ago, changed that one to push button. I bought a 140, 6 years ago, went with push button excite from beginning and it has been trouble free. Now, everytime I go to town, I don't have to be shopping for lights, diodes, resistors, etc.
I notice later in the thread you mention resistor. Heave that in the dumpster with the other junk, go buy yourself a good 12 volt coil. I use my tractors, trouble free is my game plan, fix em right and you don't have to be tinkering all the time.
