Re: Update on M not starting.
Posted by Caseman 49 on November 29, 2006 at 08:51:19 from (189.155.85.50):
In Reply to: Update on M not starting. posted by unioncreek on November 29, 2006 at 08:30:55:
I would do two things first. Sounds like the condensor may be bad. Replace it first, then clean and regap the points. You can take the mag off the tractor and put it in a vise. Put a plug wire in the mag with a spark plug on the other end. Make sure the plug is grounded to the vise. You then can fire the mag by hand to check the spark. Reinstall the mag. Tractor supply usually has parts for the mags. Good luck and dont freeze.
