Re: !953 H tractor
Posted by Janicholson on November 30, 2006 at 10:54:57 from (199.17.6.122):
In Reply to: !953 H tractor posted by Ronald Kline on November 30, 2006 at 06:45:17:
Quick check: take the bolted on lead from coil to dist, off of the out side of the distributor. Take the coil wire out of the distributor tower and place it close to the block (1/16"). Turn on the ignition then intermittently touch the first lead you removed to a bare metal ground. this will act like a set of points, causing (hopefully a spark at the coil wire. It will not be much of a spark because the condenser is not hooked up, but it is diagnostic.
If spark, the problem is in the distributor. Probably a grounded part. JimN
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
