Re: Att Bob
Posted by Tom Windsor on November 30, 2006 at 21:05:21 from (64.12.116.65):
In Reply to: Re: Update - M is up and running. posted by Bob on November 30, 2006 at 20:50:33:
"So, as you hand-crank it with the "kill switch" in the "stop position", you will hear the impulse "snap" at #1 TDC."
Does this sentence mean that the mag should be adjusted so that on "snap"...the piston be at TDC? I think that is what you said...??
