Re: moving a 300U
Posted by old on November 30, 2006 at 21:31:58 from (4.244.90.128):
In Reply to: moving a 300U posted by Bill Geer on November 30, 2006 at 21:19:49:
If I where you I would use a trailor even if you have to rent one. We hauled a 300U on a 16 foot car hauling trailor with no problems. Biggest reason isn't that it will hurt the TA but because of safety and brakes not working well on the tractor
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
