Re: moving a 300U
Posted by Bill46 on December 01, 2006 at 05:03:31 from (63.65.68.246):
In Reply to: moving a 300U posted by Bill Geer on November 30, 2006 at 21:19:49:
Don't tow it...haul it. If you go too fast you may dammage the thrust washers in the transmission and it will not go in gear. Did that once on a Super H which is basically the same drive train.
Put it on a trailer and be safe.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
