Re: 340 U Hydraulic Oil Change?
Posted by JayWalt on December 01, 2006 at 11:49:11 from (24.223.138.48):
In Reply to: 340 U Hydraulic Oil Change? posted by suumoe on December 01, 2006 at 10:35:11:
The bad thing about changing the fluid is all of the residual fluid. What I would do is I would unhook the distributor and bump the engine over a few times so the hydraulic pump can expel all the fluid into the resevoir. Make sure u prime it after putting in new fluid the same way. Unless you got 20 gallons laying around to change it after a few hours again, but that stuff is $$$
