Re: super h will run a little will then blow a co
Posted by BIG JOHN on December 02, 2006 at 11:27:06 from (24.124.104.112):
In Reply to: super h will run a little will then blow a conden posted by na na on December 02, 2006 at 10:50:35:
If your tractor has been converted to 12v and you don't have a "Balast Resistor" between the feed and your coil. You will be feeding 12v directlly thru your coil to the condensor which is a 6v condensor.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
