Re: super h will run a little will then blow a co
Posted by Bob on December 02, 2006 at 11:58:31 from (69.178.229.154):
In Reply to: Re: super h will run a little will then blow a co posted by BIG JOHN on December 02, 2006 at 11:27:06:
The breakdown voltage of the condensors is in the 200 Volt to 600 Volt range, whether for a 6-Volt or 12-Volt ignition system.
If there is no ballast resistor used, and one is needed, primary current will be excessive, shortening breaker point life. However, the condensor shouldn't be affected.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
