Re: Charging Battery on M
Posted by Roger Mills on December 02, 2006 at 13:04:51 from (204.13.130.86):
In Reply to: Charging Battery on M posted by Steve Laaveg on December 02, 2006 at 12:34:10:
You did right, charger goes plus to plus etc. The positive ground to the tractor is normal for 6 volt sytems and has nothing to do with an external charger. If the battery was dead for a long time stuff builds up in the cell separators and can short the cells out.
