Re: rear main seal replacement on IH W4
Posted by 55 50 on December 02, 2006 at 16:44:40 from (216.114.212.109):
In Reply to: rear main seal replacement on IH W4 posted by n8terry on December 02, 2006 at 14:56:00:
Not sure on a W-4, but on a WD-9 we had to lift the motor and set it crosswise on the main frame (oil pan was off) to get to the rear main. Of course we found out later that the rear main bearing was worn and that was why the original oil seal was leaking. You may have a bad rear main bearing if the seal is leaking.
