Re: 300u starter
Posted by Rustyfarmall on December 03, 2006 at 13:34:44 from (207.32.13.209):
In Reply to: 300u starter posted by Jimer on December 03, 2006 at 13:15:01:
Most likely the teeth on the ring gear attached to the flywheel are chewed up and worn, and there is very little for the starter drive to engage into. You can either put up with problem and hope it doesn't get worse, or you can split the tractor and replace the ring gear.
