Re: light switch location for 400
Posted by Janicholson on December 03, 2006 at 17:22:22 from (66.173.50.104):
In Reply to: light switch location for 400 posted by SDE on December 03, 2006 at 17:10:13:
SDE,
I think you are better off with a waterproof switch. My reasoning is that I have seen many many rusted water dammaged switches ment to be used on the dash of cars. I would put the switch in a plastic, or aluminum mini box (from Radio Shack, cheap) use a strain relief on the wire hole, and use double stickie foam on a convienient side to stick it to the side of the dash in a handy location out of the path of movement. Use a full side covering of the foam tape to assure good adheasion, and clean the flat painted surface to stick it on with a bit of laquer thinner to assure there is no wax, grease, or oxidized paint to help it come off. That is my best plan that doesnot make holes in the dash or Bat box. I would connect the power lead to the starter solenoid battery connection with a large crimp on connector, and shrink tubing. It should be fused for about 15 amps inline to prevent fires. Good luck, I hope this helps, JimN
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
