Re: Charging Battery on M
Posted by Steve Laaveg on December 03, 2006 at 17:24:25 from (24.230.71.190):
In Reply to: Charging Battery on M posted by Steve Laaveg on December 02, 2006 at 12:34:10:
I did hook it up wrong for an extended time after I briefly had it
hooked up right. When I went inside to check my post and you
guys set me straight, I took the battery away from the tractor
and hooked it up to the charger the "correct" way, only to have
the charger kick out instantly (you could here a relay clicking
inside it). I took the cables away from the posts and the charger
would come to life again. I must have ruined it!?. Nevertheless,
I went to town and got a new Fleet Farm battery, smaller than
the original(625 cca) and put it on the cables and I was able to
start it. Today I went out to start it and it won't start (no charge
on the ammeter). I had left the ignition switch pulled out-would
this lead to a discharged battery? What would cause it to drain
down if there were no lights on? My true Norwegian heritage is
showing throug on this one-thanks for all the help you guys.
This is my first time to this site and I like it alot!
