Re: MD serial number on eng
Posted by Haas on December 04, 2006 at 18:30:02 from (12.65.78.72):
In Reply to: MD serial number on eng posted by petenev on December 04, 2006 at 09:26:28:
The engine serial number is located on the left side of the crankcase (engine block). It's just in front of the diesel speedcontrol/gas to diesel switchover unit that is mounted on the left side of the block. Also just over the top of the oil fill port for the injection pump. There is a flat raised place on the block. The serial number is stamped on that.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
