Re: buckets
Posted by Hugh MacKay on December 06, 2006 at 02:47:37 from (216.208.58.126):
In Reply to: buckets posted by redboy656 on December 05, 2006 at 11:27:40:
redboy: It would help to know the model number of the loader. There were probably 1/2 dozen loaders installed on 656s over the years. Tractor model tells very little.
If the loader is an IH 2000 or newer, most any modern day loader bucket could be made to fit with a bit of fabrication. Most all loaders using two bucket cylinders out front on loader arms, have the same basic configuration as it applies to the bucket. You might even find a fabricator to make you up a universal quick attach plate for the loader, then sky is the limit on buckets. Bear in mind it has to be an IH 2000 or newer loader.
