Re: Lift All's
Posted by D Slater on December 06, 2006 at 06:16:30 from (152.163.100.65):
In Reply to: Re: Lift All's posted by BOBM25 on December 06, 2006 at 05:34:03:
I looked to make sure and the gas pump 4 mounting bolts will not line up on your diesel. The drive gears are different also,but that could be changed and maybe a outside chance parts of both pumps could be cobbled togeather to bolt up.You have the wrong manifold for sure the suction or big hose is to outside on diesel.The steel line on original went from manifold up over oil filter and then had a short hose if remote control valve was used or longer hose back to reservoir if not used. steel line used fittings on both ends and hose was not part of line.
