Checking coils and wiring
Posted by relane on December 07, 2006 at 06:39:08 from (170.215.20.11):
Hi, How do you check a coil to see if juice is getting to it and then going through it. Does the wire from the battery have to go to a regulator and then the coil or can it be bypassed and go directly battery(-) to coil, per example that i found, my tractor does not have lights, so im not worried about the wiring to the light switch in this example. Thank you for your thoughts.
[IMG]http://i11.tinypic.com/4hwgl8p.jpg[/IMG]
