Re: Checking coils and wiring
Posted by Bob M on December 07, 2006 at 07:11:39 from (151.190.254.108):
In Reply to: Checking coils and wiring posted by relane on December 07, 2006 at 06:39:08:
Relane - To check if the coil is getting power, remove the distributor cap and temporarily block open the breaker points (manually open the contacts then place a match flap, $1 bill or similar between ‘em).
Now turn on the ignition switch and test with either a voltmeter or low current test light. If everything is OK you will see battery voltage between BOTH coil primary terminals and a good ground.
If no voltage at either coil terminal the coil is not receiving voltage – look for a bad ignition switch or wiring to/from the switch.
If voltage is seen only at the coil's ignition switch (-) terminal but not at the distributor (+) terminal, the coil is bad (open circuit in the primary).
Power for the ignition switch should be taken from the ammeter post NOT connected to the battery. It'll work connected directly to the ungrounded (-) battery terminal, but it will cause the ammeter to read incorrectly.
Hope this helps!
