Re: Newly acquired IH 606 -- Where to start?
Posted by Erik in WI on December 07, 2006 at 16:36:29 from (65.162.45.160):
In Reply to: Newly acquired IH 606 -- Where to start? posted by Hannibal on December 07, 2006 at 07:15:53:
I would drain the fuel tank. Diesel fuel does not last forever, and there will be water in the fuel from sitting. The condition of the hydraulic fluid is unknown, so I would recomend changing it and the filter as well. Use Hy-Tran, which can be purchased at your local Case dealer, along with the filter. When you have the filter out, look for any metal shavings, which is a good warning of a bearing going out.
If everything goes well, you will have one heck of a tractor for the money.
Good Luck
Erik in WI
