Spliceable Urethane belt.
Posted by JayWalt on December 08, 2006 at 02:16:59 from (24.223.138.48):
Was wondering if anyone has ever used this. It is primarily used in converyor systems:
http://cgi.ebay.com/Eagle-URETHANE-V-BELTING-Spliceable-A-100-feet_W0QQitemZ7596800674QQihZ017QQcategoryZ1267QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
I was hoping to use it to fix my generator belt on my 300u, as I cant remove the waterpump belt because the setscrew in my waterpump pulley is broken off. I do not plan to use the tractor in the cold weather, so the cold isnt a concern. I'm not sure how it would hold up to the engine conditions. I'm pretty sure that it would work for the generator, as its no more then 1 HP I assume. One concern is the tight radius around the generator. This type is spliced by using a hot peiece of metal between the 2 ends and then its slide out the the 2 ends are "melted" togther. The other type uses a double ended barb, but I've read that they arent too tolerant of tight radiuses such as th generator pulley.
I dont need 100ft of it, so if anyone would be interested in purchasing some from me, let me know. I would only charge realistic cost, not looking to make a profit.
Thanks for any opinions, Ideas and whatnot. In an ideal world, I would like to pull the radiator, and pull the waterpump off and drill out the setscrew, and retap the pully. I'm not sure I'd be able to separate the 2 pulley halves anyways. The waterpump belt is in like new shape, with the white lettering clearly visible, so that should last several years.
