Re: M steering --Grease or oil?
Posted by glennster on December 08, 2006 at 05:54:55 from (68.79.57.230):
In Reply to: M steering --Grease or oil? posted by Den T on December 08, 2006 at 05:37:00:
you may want to change the seal in the upper part of the housing. its located on the lower part were the shaft comes up thru to the worm and sector. i used a piece of pipe to get the seal up in there, its either 1" or 1-1/4. also use emery paper and shine up the seal surface on the shaft. i had mine apart a couple of times went thru 2 seals before i finally figgured out i needed to shine up the shaft a little. sometimes i just plain get a brain f*rt.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
