Farmall Tractors Discussion Board
Re: Super C Oil Pressure Tick
Posted by HR on February 02, 2000 at 05:13:57 from (207.115.63.29):
In Reply to: Super C Oil Pressure Tick posted by Red Raider on February 01, 2000 at 19:08:10:
Red Raider: You said it is CONSTANT at all RPM and oil temps? That gives me a hint that it may be the gauge itself? It often is a flat needle pushed down on a small shaft. If over time it becomes a bit loose, it could cause a tick from normal engine vibration? Just guessing because you seem to think your engine is in very good shape other wise. Try another gauge? Best of luck. . harvey
Post A Followup
: Re: Re: Super C Oil Pressure Tick
