Re: international 125B
Posted by Fromjb2 on December 08, 2006 at 18:14:06 from (74.101.67.211):
In Reply to: international 125B posted by Kieran on December 08, 2006 at 13:33:55:
Hi Kieran, the German build D239 was used in many agricultural tractors 574,674,684,685,695,4210.
The 574 thru 685 used a Bosch VE 4/10H 1200CR12/12 injection pump and the 695 and 4210 used a Bosch VE 4/11F 1200R277 injection pump.
The fuel and throttle control hookups for the different Bosch injection pumps are different.
Most common problem with the older Bosch pumps was the front seal on the drive shaft would wear out and let Diesel fuel leak into the crankcase oil. Seal is about $8.00 but have to remove pump to replace.
Hope this helps
JB2
