Re: IH 2000 Loader-Need Advice
Posted by Nat 2 on December 09, 2006 at 15:32:25 from (69.204.107.149):
In Reply to: IH 2000 Loader-Need Advice posted by KDJ in IA on December 09, 2006 at 05:13:45:
KDJ, The 2000 loader is a pretty big loader for an M. It's not even meant to go on an M. I've got a manual and it doesn't even go into installing one on an M due to the lack of high-capacity, two-way hydraulics that the loader really needs to work properly. Speed is a function of GPMs, gallons per minute, and even if this M has a live pump, it's not going to set any land speed records moving the loader. It's going to be slow. Sounds like the arms are plumbed for pressure-up and gravity down using the tractor's standard 1-way hydraulics. Do you pull the lift rod that goes to the belly of the tractor to raise and lower the loader? The belly pump doesn't hold enough fluid to lift the loader all the way by itself. The hose and TEE that run under the belly are probably plumbed into the belly pump's drain port, and the "dead" side of the cylinders are supposed to be filled with oil to supplement the belly pump reservoir. To get "power down" for the arms you will need to add a two-way valve into the system. To make it go faster, you will need to get a different tractor. You can add the wide front, no problem.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
