Re: Kind Of An IH Question......................
Posted by Clarkbug on December 10, 2006 at 10:43:24 from (72.66.38.227):
In Reply to: Re: Kind Of An IH Question...................... posted by Nat 2 on December 10, 2006 at 08:29:05:
Hey there.
Im pretty sure he actually did use a hydraulic fluid when he filled things back up. I know we have an add-on valve that bolts to the trans. cover that give you hyraulic remote. It uses the 3 pt. pump to run an external cylinder. So my guess is that he wouldnt use gear lube in there, but then again crazier things have happened...
Hydraulic fluids are all supposed to be similar viscosies, correct?
And I didnt know if Permatran was just a factory name, or if it was actually a different type of oil.
