Re: 130 update, up and running
Posted by Hugh MacKay on December 10, 2006 at 12:34:01 from (209.226.247.46):
In Reply to: Re: 130 update, up and running posted by Al L. in Wisc. on December 10, 2006 at 09:40:05:
Al: They sure do, went out since lunch and 130 didn't want to turn over. I fooled with it for a few min., then decided I was getting poor connection at battery cables. I had a couple light duty automotive type cables with bolt on ends I'd put on there last summer to be temporary. I went to work stripped those light cables. Got out the 1 gauge I'd bought, soldered on ends, and made up a complete new set of cables. Ah, those new heavy cables, make it seem like a new battery. She'll turn that engine now at close to speed of 1/3 throttle.
The distributor drive will actually turn out for the better. I'll put those new gears in the Super A, my keeper tractor. This 130 has seen a lot of hard hours in the past 48 years. This is the 3rd time I've been going to part it out, however deep down I know that isn't going to happen. It blows smoke, leaks oil at front seal, fouls up number 2 plug from time to time, yet it will still lug with 140 and Super A. It's got new front tires and rims, new water pump, complete new clutch assembly, I completely refurbished all pins and pin holes in fast hitch and rebuilt the steering box, he!!, I cant quit now.
I've never really wanted to put the snow blade on Super A or 140. I'll bet that 140 has yet to see 500 hours use since new, Super A maybe 1,500 hours. Just nicely broke in. Snow plowing is mean work, not kind to a tractor, especially when you go at it as hard as I do. So I guess 130 remains the beater. I plowed snow too many years with articulated Deere and a Champion 250 road grader, and expect the 130 to push that big pile as well. It doesn't always work, but I'll tell you considering size of 130, the others don't look great.
When the tractor stopped on Fri. I had a good idea what was wrong, thought I'd ask the YT guys just in case I was missing something. But you know these old 4 cylinder gas Farmalls will go, if they are getting gas, have fire, and the fire happens when piston and valves are in the right position. Never seen it fail, they may not start on starter or crank, but you tow start them and in 20' they are usually going. If that doesn't happen, they are not going to start.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
