Re: 48 Cub with problems
Posted by Bus Driver on December 11, 2006 at 05:16:13 from (66.44.243.224):
In Reply to: 48 Cub with problems posted by Tom671 on December 11, 2006 at 04:44:04:
Two belts on the Cub, the fan belt and the generator belt. The fan belt is adjusted first. Use a 13/16" open end wrench just in FRONT of the support for the fan shaft. The nut on the back is captured in a wide groove and will not turn.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
