Re: Fluid in my H?
Posted by RustyFarmall on December 12, 2006 at 10:00:33 from (216.248.75.140):
In Reply to: Fluid in my H? posted by Aaron B on December 12, 2006 at 09:40:45:
The belly pump will hold 6 quarts of oil. Original specs called for non-detergent motor oil, 30wt for warm weather, 20 wt. for cooler weather. HyTran or its equivalent is perfectly acceptable. There is no check plug. Originnaly there was a dipstick that lived just under the fill cap. Mosy of them are gone, You don't need it. The belt pulley gear box uses the same gear oil that the transmission/rear end uses.
