Farmall Tractors Discussion Board
Re: Re: I need more help with 656D
Posted by twopop on February 02, 2000 at 17:31:51 from (208.224.41.26):
In Reply to: Re: I need more help with 656D posted by Joe Acker on February 02, 2000 at 13:58:15:
I TALKED TO A FRIEND WHO KNOWS MORE ABOUT IH THAN I DO, AS HE REMEMBERS,THE SHIFT LEVER FOR THIS TRACTOR IS ON THE RIGHT SIDE OF THE DASH,IF SO, HE SAYS THE PROBLEM IS PROBABLY THE ROLLERS ON THE SHIFT CAM.THIS IS LOCATED UNDER THE TRANS COVER AT THE OPERATORS FEET. TAKE THE COVER OFF AND TURN IT OVER,YOU WILL SEE THE ROLLERS.PROBABLY ONE OR MORE OF THE ROLLERS WILL BE WORN.IF SO REPLACE THE ROLLER AND PIN... ALSO CHECK THE LINKAGE BETWEEN THE TRANS AND SHIFT LEVER FOR WORN CLEVISES AND BELLCRANKS
P.S. BUY THE TRACTOR
Post A Followup
: Re: Re: Re: I need more help with 656D
