Re: 3 Cylinders...1 to go!
Posted by Keith-OR on December 14, 2006 at 20:15:56 from (207.200.116.5):
In Reply to: Re: 3 Cylinders...1 to go! posted by JayWalt on December 14, 2006 at 19:57:47:
Jay, I don't think he is thinking about grease getting down to the rings. If he fills cylinder with oil and make sure valves are closed on that cylinder, the grease gun puts out in excess of 1000psi. Therefore he will be using high presure to get piston to break loose.HTH
Keith & Shawn
