Re: 3 Cylinders...1 to go!
Posted by JayWalt on December 15, 2006 at 01:18:31 from (24.223.138.48):
In Reply to: Re: 3 Cylinders...1 to go! posted by old on December 14, 2006 at 21:05:02:
If he does decide to pull the head and can get the sleeve out with the piston still froze in it, he could try throwing it in the oven (after all the flammables have evaporated) at about 300-350 degrees for about 20 minutes, the sleeve will expand and might break the piston free. It's worth a shot I guess.
