Re: Which light styles
Posted by SuperA-Tx on December 15, 2006 at 18:41:35 from (4.226.54.103):
In Reply to: Re: Which light styles posted by Wardner on December 15, 2006 at 17:55:19:
I just used a can of that heat resistant aluminum paint to spray mine with and it worked out real good. Used that on the gas cap and radiator too after a trail and error. I had used the regular aluminum spray paint first but it came off when you rubbed it. That heat resistant paint is pretty good stuff.
Roger, theres a rubber gasket around the light body that the lens sits on then the ring that you screw down to hold it all together. You'll need that rubber gasket to make it all tight and water resistant. Mine were all gone cept one and it was all tore up.
OEM sells them, they arent expensive.
