Re: Super A brakes
Posted by kevinez on December 16, 2006 at 09:52:05 from (66.37.71.114):
In Reply to: Super A brakes posted by jerry vanderheite on December 16, 2006 at 08:41:03:
I'm going on that you are removing drop housing that has the extension tube on it (just below the seat). When I removed mine it was during a total disassembly of the tractor for restoration (still ongoing). I found that the extension tube and the drop housing were pretty much stuck together after being together for 50+ years. It took me some time with judicious tapping evenly all around. Be careful as these are cast pieces and banging away at them can break them. Also, the pin that holds the brake end together may have rusted tight and is causing you your difficulties. On another note, you may not be doing this, I had some difficulties removing the brake drum as it machining tolerance was tighter than spec'd. Had to make a special puller to remove it. You'll need to remove it if you are going to replace any failed seals. Good luck.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
