Re: CUB Battery drain, hum?
Posted by El Toro on December 18, 2006 at 08:03:02 from (205.188.116.133):
In Reply to: CUB Battery drain, hum? posted by Courtland on December 18, 2006 at 06:59:11:
I would check the ignition switch with a volt meter to see if voltage is still present when in the off position. Hal
