CUB Battery drain, hum?
Posted by Courtland on December 18, 2006 at 06:59:11 from (146.243.4.157):
52 CUB-6volt, battery ignition system. New wire harness..
Problem: Battery drains when tractor is shut off...Have noticed when Points on distributor are "closed" battery will drain...what causes this and how can I fix it?
Courtland
