Re: Starter needed or just maintenance?
Posted by CENTAUR on December 18, 2006 at 11:17:09 from (75.28.13.177):
In Reply to: Starter needed or just maintenance? posted by ToddH on December 18, 2006 at 09:23:58:
Put new longer brushes in their.Replace bushings if needed and always lube.Keep your original starter if possible as they are better. Do not turn Armature if it has one or more segments burnt as that would show a bad winding or windings. Do not turn since it can cleaned with sanding unless it will not conform to the new brushes CENTAUR
