Re: Sparking starter button on my H
Posted by old on December 18, 2006 at 12:24:22 from (4.244.90.20):
In Reply to: Re: Sparking starter button on my H posted by neblinc on December 18, 2006 at 12:12:55:
If it sparked you probably had a wire/cable loose and when she hit the button it welded its self are burned it just enough to fix the loose condition. If I where you I would check the nuts on the starter switch and you will probably find one just a little loose
