Re: WD-9 Duals
Posted by iowa_tire_guy on December 18, 2006 at 19:48:11 from (69.63.29.218):
In Reply to: WD-9 Duals posted by mib61 on December 18, 2006 at 18:17:11:
The rear ends on the W9s were not over built, at least that is the word from a relative who wrenched in an IH dealership in the 50's. I would think that for no more hard work than you do with it you wouldn't have a problem as long as you aren't kicking op the hp or adding weight. I just happen to have a set of rim clamp duals for 18.4-34 if you would need them.
