Re: farmall H repost
Posted by Tom Windsor on December 20, 2006 at 15:43:40 from (205.188.116.133):
In Reply to: farmall H repost posted by voager213 on December 20, 2006 at 14:31:30:
Lots of folks do a lots of things under the hood of the H including the conversion to the 12 volt system. Again "I think" you are going to depreciate the value of your tractor by making this conversion because it is just not the way it came from the factory. I personally think it is worth more with the factory system working. It is no big deal to fabricate the battery cables. Keep in mind that you need large cables...I believe it is #8 braded wire--might be #6, I cannot remember.... As indicated, the repair of the generator is about $100.00 and maybe $40.00 for voltage regulator--yours might not be bad. I suggest that you shop around and find a 9 V battery to replace the 6V. Yes, I did mean 9 V They are unusual but available. This will not require any modification of the coil or anything else.
TW
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
