Re: hydro fluid leaking out of my 51 h
Posted by Janicholson on December 20, 2006 at 17:34:08 from (66.173.50.116):
In Reply to: Re: hydro fluid leaking out of my 51 h posted by city farmer on December 20, 2006 at 17:11:56:
If it is comming out of the cover behind the pump, but in front of where the hitch swinging drawbar attaches, it is probably trans 90 wt oil (especially if it smells sulfery) that seal is also in the same location and the pump needs to be pulled to service it. A stiff square 1/2"X1/2" bar will turn the coupling nut off (many posts on the countershaft seal on Hs and Ms). No big deal, keep the fluid up in the interum (plug on left in front of left brake on side of trans) should be within one finger joint of the bottom of the plug hole. JimN
