farmall m lift all question
Posted by Mike Schwartz on December 20, 2006 at 23:04:22 from (65.162.174.161):
Hello, The farmall M that I am working on has a Horn loader that has two stage hyd cylinders on it. The fluid capacity of the original pump is not enough to fully raise the loader. Can I add an additional resevoir above the pump to increase the volume of oil without causing problems? Also, can I use the factory two way valve off of my SMTA with live Hyd on the '51 M with belly pump? Thanks, MikeS.
