Re: OT broken valve spring
Posted by Tom in Central Pa on December 23, 2006 at 03:01:58 from (207.255.71.69):
In Reply to: OT broken valve spring posted by Bummer on December 23, 2006 at 01:10:40:
I would only replace the one spring, without removing the head. On the older models, it was possible to pressurize the cylinder thru the sparkplug hole with compressed air. Pull up and close the valve, the compressed air would hold it there. Then using the proper spring compressor, remove the valve retainer and replace as necessary. All the tools I used, air fitting, compressor, were from K-D.
