Re: OT broken valve spring
Posted by KEB on December 23, 2006 at 08:17:02 from (72.19.170.5):
In Reply to: Re: OT broken valve spring posted by Tom in Central Pa on December 23, 2006 at 03:01:58:
If you use compressed air, make sure the engine can't turn, or better yet put the cylinder you're working on at bottom dead center. Once you've removed the rocker, the valve can stay closed regardless of the position of the camshaft.
A compression tester with a removable guage on the end of a hose makes a nice adapter. Mine has the same male quick coupler on the end of the hose that air tools do.
Keith
