Re: UpDate On M
Posted by kfox on December 24, 2006 at 08:43:21 from (63.18.243.2):
In Reply to: UpDate On M posted by LinemanFarmer on December 24, 2006 at 07:46:39:
Derek, Thats must be a pretty standard problem on the letter series Farmalls with a working battery starter. I've had 3 Hs with the same problem. There is a sleve/ratchet in the bolster that is rusted in place. Sometimes you can soak em with penetrating oil and beat em loose. Worse case-remove the bolster & heat. There is a grease fitting on the bottom of the bolster that most guys ignored when they could just push the starter button. ken
