Re: boring the block
Posted by Tom Windsor on December 24, 2006 at 20:12:24 from (64.12.116.65):
In Reply to: boring the block posted by north Dakota H puller on December 24, 2006 at 20:01:44:
Chad
The numbers do not add up--if they do, I have never seen them---"I thought" that the largest sleeve for the H was the 3 7/16 bore.
I am not sure that your idea of boring the block to accept a larger piston without sleeves will work on this engine..but in all events, I would prefer my pistons to be sliding up and down in a steel sleeve--simply because when the wear out you can pull them and put another set in. I think I would put in 3 7/16 stepped pistons with sleeves.
